Ethernet Cat 5 Cables
Two new 600-V AWM-rated shielded cables join the company’s DataTuff Industrial Ethernet line
Two new 600-V AWM-rated shielded cables join the company’s DataTuff Industrial Ethernet line. The Category 5e cables feature bonded-pair technology and are designed for use in listed motor-control centers and switch gear in tough EMI environments.
Both four-pair shielded cables feature rugged construction and their AWM rating allows them to be used on or within a listed cabinet or machine. However, they are not intended for 600-V power delivery.
The cables also feature an overall shielded design with 24-awg bonded-pair solid bare-copper conductors, polyolefin insulation, a 24-awg stranded tinned-copper drain wire, and an industrial-grade oil and sunlight-resistant PVC jacket.
Belden, Box 1980, Richmond, IN 47375, (800) 235-3361, www.belden.com
© 2011 Penton Media, Inc.
