Detection Sensors can be Used In Multiple Applications
The Contrinex C23 standard and clear object detection sensors are mini rectangular photoelectric sensors for use in limited-space applications and are available in diffuse, diffuse with adjustable background suppression, retroreflective and through-beam models. Sensor housings have an IP67 enclosure rating and are ECOLAB-approved for use in hygienic areas. The Contrinex TRU-C23 UV photoelectric sensors are designed for detecting transparent objects, such as those made with plastic or glass.
Since transparent materials absorb large amounts of polarized UV light, it is very easy to set the threshold at which these sensors switch. Select models are IO-Link compatible, providing continuous diagnostic information and easy remote sensor mode selection along with accurate object detection data. All sensor outputs are complementary, allowing them to be used as a light-on or dark-on sensor.
