AutomationDirect
AutomationDirect's Contrinex sensors
Photoelectric Sensors are IP67 Rated
Feb. 11, 2022
AutomationDirect's Contrinex sensors are available in several different models.
Contrinex metal M12 and M18 photoelectric sensors for process and discrete control applications offer complete overload protection and are IP67 rated. They are available in diffuse, diffuse with adjustable background suppression, retroreflective and through-beam models. Select models are IO-Link compatible, providing continuous diagnostic data and easy sensor mode selection.
All sensor outputs are complementary, allowing them to be used as a light-on or dark-on sensor. The Contrinex photoelectric sensors are made in the USA and are UL listed, CE marked and RoHs compliant.
AutomationDirect
