Stability Sensor
The FlexiForce Enhanced Stability Series 301 sensor is made from the company’s Enhanced Stability Series (ESS) pressure-sensitive ink. It gives the sensor the added benefit of measuring force in a wider temperature and humidity range. The ESS301 sensor is three times less sensitive to heat and humidity compared to the FlexiForce standard sensor and performs better over a wider range of environmental, operating, and storage conditions.
Tekscan Inc., 307 West First St., Boston, MA 02127, (800) 248-3669
Related
Supplier Submitted
