Cushioned pneumatic air cylinders
Oct. 28, 2013
The D-Series double-acting, heavy-duty air cylinders, for use in abusive conditions, have a 250-psi operating pressure and are interchangeable with other brands. These models are available with adjustable cushions to provide end-of-stroke deceleration at both ends.
Constructed with high-quality aluminum, the cylinder’s magnetic piston is fitted with a PTFE wear band. The cylinders can be used along with solid-state or reed switches for rod-position sensing. Bore sizes range from 1½ to 4 in. and stroke lengths from 1 to 24 in. Models feature flange, rear clevis and rear pivot, side, and rod clevis mounting options.
AutomationDirect,3505 Hutchinson Rd, Cumming, GA 30040. (770) 889-2858, www.automationdirect.com
