What's Inside?
Highlights
Two-Speed Gearbox Provides High Speed and High Torque
Engineers at Stober have designed and built the PS Two-Speed gear box to quickly and efficiently carve complex parts out of modern metals.
Are Holding Brakes Shrinking?
Ogura shows how the MTNB/TNB series brake works.
Hall Sensor Measures 360 Deg. of Rotation
Engineers who want to measure and control rotating antennas, fluid flow direction, or a robotic arm joint can now use a Two-Pi hallpot angle sensor from Elweco Inc.
Creating Larger Forces with Differential Roller Screws
Schaeffler’s PWG differential roller screw can create up to five times the force of a ball screw, making it ideal for hydraulic systems.
Wireless, Energy-Harvesting Switches Transmit Data More Than 900 ft.
Wireless AFIS rocker and snap switches can harvest the energy needed to send a radio message containing all user data via an antenna.
Machinedesign 7499 605mad10promoweb 0
Software Update Leads to Faster, Cheaper 3D Printing
Updates to the Form 1+ SLA model software help to improve 3D printing.
Machinedesign 7405 Aventicspromo 0
Pneumatic Cylinder Designed to Stay Clean
With an eye on hygiene, Aventics' new mini pneumatic cylinder was designed using roll-in geometry for its cover to prevent dirt accumulation.
Machinedesign 7558 Memsic Wi Imagepromo 0
Sensor Leverages Thermodynamics to Measure Gas Flows
MEMSIC's MFC2000 series gas flow sensor measures up to 70 liters per minute of gas flow with a minimal pressure drop.
Machinedesign 7381 Kollmorgen Eci Wi Promo 0
Compact, Electric Cylinders Lower Costs
The EC1 Linear Positioner from Kollmorgen, Redford, Va., has a maximum stroke length of 200 mm and delivers thrusts of up to 150 lb. at 13 ips.
