Rotomolded plastic replaces concrete
A Netting TrashTrap system from Fresh Creek Technologies Inc., Cedar Grove, N.J., captures floating trash and debris before they disrupt sewer systems or pollute waterways.
Jan. 10, 2008
2 min read
But the company knew its large concrete system would be too costly and cumbersome for the low- flow (1 to 5-cfs) stormwater market. To make it lighter, the company worked with the plastics design and manufacturing firm Meese Orbitron Dunne Co., Madison, Ind.
MOD engineers designed a rotationally molded alternative using advanced 3D modeling that eliminates the weighty concrete vault and cover, and stainless-steel doors. The housing for the Trashmaster Net Capture System is a single rotationally molded part made from durable high-density polyethylene (HDPE), with a manhole cover for access. The housing costs about half as much, is one-fourth the weight, and installs in a day with on-site equipment, compared to a week for its concrete counterpart. The plastic part fits pipe up to 24 in. diameter and installs to a depth up to 10 ft.
To help speed installation, Meese Orbitron Dunne Co. preassembles the Trashmaster Net Capture System with custom-engineered pipe couplings, framing, and other internals. It then ships the rotationally molded unit directly to the job site.
