Insidepenton Com Images Disc Springs
Disc springs
Sept. 29, 2011
Conically shaped disc springs are washer-type components designed to be axially loaded. The springs can be used individually or stacked to achieve the desired deflection characteristic required for an application
Conically shaped disc springs are washer-type components designed to be axially loaded. The springs can be used individually or stacked to achieve the desired deflection characteristic required for an application. The springs provide high levels of load/force within a very small space. The springs predictability, high reliability, and unparalleled fatigue life make them suitable for critical applications such as safety valves, clutch and brake mechanisms for elevators and heavy equipment, and supports for industrial pipe systems.
Spirol International Corp.
30 Rock Ave.
Danielson, CT 06239
(860) 774.8571
www.spirol.com
© 2011 Penton Media, Inc.
VICIS Case Study
