Cognex
In-Sight 2800
Vision System Provides Easy Set-Up, Deployment
April 25, 2022
Cognex's In-Sight 2800 blends deep learning and traditional vision tools.
The In-Sight 2800 series vision system puts the power of a full-featured vision system into an easy-to-use package that gets applications running in minutes. In-Sight’s EasyBuilder interface guides users through the application development process step-by-step, making it simple for even new vision users to set up any job. Experienced users will appreciate how In-Sight’s intuitive, point-and-click interface simplifies more complex application development and keeps operations moving fast.
The combination of deep learning and traditional vision tools gives users the flexibility to solve a broad range of inspection applications - operators simply select the tool designed to deliver the highest possible accuracy for their task. Tools can be used individually for simple jobs or chained together for more complex logic sequences.
Cognex
May 7, 2024
May 7, 2024
May 7, 2024
