GM standardizes on Ethernet/IP
Jan. 22, 2004
General Motors Corp., the world's largest vehicle manufacturer, recently standardized on the Ethernet/IP network for its vehicle manufacturing operations. The network is slated to provide real-time communication between machine controllers, robots, process-control equipment, and provide information to higher-level business systems. GM suppliers in America, Europe, and the rest of the world have until January 1, 2007 to make their products Ethernet/IP compatible.
Introduced in early 2000, Ethernet/IP is based on commercial off-the-shelf Ethernet (IEEE 802.3) and the TCP/IP suite, not modified, proprietary implementations. It also uses User Datagram Protocol/Internet Protocol (UDP/IP) transport services, which supports multicast, real-time messaging. Because it uses both TCP/IP and UDP/IP protocols, GM and other manufacturers can use Ethernet/IP for both information and control applications.
Ethernet/IP also seamlessly integrates with DeviceNet, GM's preferred device-level network in North America. It also uses the Common Industrial Protocol (CIP) as its upper-layer protocol and object model. CIP lets users transport data from the factory floor to enterprise systems without specialized devices or software.
Sept. 16, 2025
Sept. 16, 2025
Sept. 16, 2025
