Julie Kalista
Online Editor
| The minimal components of the integrated electric generator. |
| The tested prototype. |
Most current tidal stream generators are just wind turbines that work underwater. The new generator eliminates complex gearboxes used in current marine turbines, the parts that often require expensive maintenance. Because it requires less power it is also cheaper to run. Turbine blades work equally well no matter what direction water flows past them so there is no need to turn to face the direction of the current, according to the team.
"Just drop the generator into flowing water and it will start generating electricity," says one of the researchers. "It works best in fast flowing, shallow water." The current prototype is 25-cm. across but the team has plans to build a larger model with improved propellers to increase efficiency.
The team hopes the generator will
be commercially available within five years.
University of Southampton
This web-only article appears in the Motors Monthly email newsletter. If you enjoyed this article and would like to read more like it, sign up today for our free email newsletters!
