Mini ball screws
Feb. 6, 2003
Miniature ball screws use internal ball return and reportedly provide high efficiency and repeatability, precise positioning, and smooth, reliable motion.
Miniature ball screws use internal ball return and reportedly provide high efficiency and repeatability, precise positioning, and smooth, reliable motion. Diameters start at 4 mm, with a 1-mm lead. Six and 8-mm diameters are also available. Manufactured as both rolled and ground units, the ball screws come in a range of precision classes. Nylon wipers protect against contamination, and ends can be machined to customer specifications.
Thomson Industries Inc., 2 Channel Dr., Port Washington, NY 11050, (800) 554-8466, www.thomsonindustries.com
April 29, 2024
