Advertisement
The gear pump operates at more than 90% overall efficiency across pressure and speed ranges.
The unit’s design reduces the potential for leak paths by minimizing plumbing, and provides excess flow from the charge valve to operate steering, cooling or implement functions.
The system comes with optional single or dual accumulator ports with four charging rates between 0.5 and 5 gpm. The unit displaces up to 1.4 cu in. with system pressures up to 3,000-psi maximum continuous.
Mico Inc.
1911 Lee Blvd.
Mankato, MN 56003
(507) 625-6426
www.mico.com
