118 Wallypower, a High-End Power Boat
| For more info on power and sailing yachts from Wally, www.wally.com |
Who cares if the fish aren’t biting? Just kicking back in the 118-ft 118 WallyPower luxury power boat made by Wally Yachts in Monaco should be vacation enough. But if speed is your thing, the boat can cruise at 60 knots for over 6 hr. Throttling back to 9 knots extends the range to 1,500 nautical miles on a tankful. Granted, the boat carries a 5,812-gallon fuel tank, but it burns 15 gallons/nm when going 60 knots. And if you can afford the nearly $25 million price tag, the price of gas shouldn’t bother you. Power is proved by three 5,600-hp Vericor gas turbines. Each turbine drives a Rolls-Royce Kamewa waterjet, giving it left and right steerable jets and one nonsteering booster on the centerline. The waterjets can also be powered by a 370-hp Cummins diesel, making it a combined diesel and gas turbine or CODOG. If you’re looking to cut corners, a twin-diesel version, which includes the waterjets, goes for just $17 million.
The boat displaces 95 tons and carries a crew of six plus six passengers. Below the waterline, the boat is constructed of fiberglass. Above that, fiberglass/ carbon composite over a balsa wood core forms the structure. The deck, which is covered in teak, is Nomex/carbon composite. The superstructure is also covered in panels made of triple-laminate glass and Lexan. Interior bulkheads carry no loads, so they are thin wood and laminate veneers over lightweight cores. Bath fixtures, dining tables, and some chairs are carbon composite to save weight. Currently, there’s only one of these super yachts plying the seas.
| Tech Specs | |
Length (at waterline) | 100 ft |
Beam | 29.5 ft |
Draught | 4.5 ft |
Displacement (half load) | 95 tons |
Cruising speed | 60 kn |
Engines | Three gas turbines for 16,800 hp |
Auxiliary power | Two Cummins diesels for 740 hp |
Range @ cruise | 380 nm |
Range @ 9 knots | 1,500 nm |
Fuel consumption @60 knots | 15 gallons/nm |
Fuel capacity | 5,812 gallons |
Fresh-water capacity | 317 gallons |
Water making | Idromat MC-105 makes 79 gallons/hr |
Generators | Two 33-kW Kohler units generate 380 V @ 50 Hz |
Navigation aids | Autopilot, GPS, Satcom, Depth-sounder, wind instruments, radar, gyrocompass |
Entertainment | Hi-fi radio, three 15-in. LCD TVs, three 20-in. LCD TVs |
Accommodations | Six guests/Six crew |
Tender | 15-ft inflatable with 40-hp engine |
