Birck Nanotechnology Center
Transactions on Biomedical Engineering
Purdue University researchers have devised miniature transducers that are implanted in tumors to generate oxygen, boosting the killing power of radiation and chemotherapy treatments. The devices get electrical power from ultrasonic waves beamed at them from outside the patient’s body.
The technology is designed to treat solid tumors that have little oxygen at their cores. Radiation therapy needs oxygen to be effective, so such tumors, which characterize pancreatic, cervical, and liver cancers, have proven hard to treat.
Purdue’s implantable micro oxygen generator harvests energy from an incoming 2.15-MHz ultrasonic wave using a lead-zirconate-titanate (PZT) transducer. Electrical energy from the PZT transducer is rectified to a dc voltage that is then applied to the water in the interstitial fluid through a set of interdigitated electrodes. This separates oxygen and hydrogen in the water in a chemical process called electrolysis.
The oxygen generators were created at Purdue’s Birck Nanotechnology Center. Researchers have tested the devices in pancreatic tumors implanted in mice, showing they generated oxygen, which led to the tumors shrinking faster under treatment. The devices are slightly less than 1-cm long and are inserted into tumors with hypodermic biopsy needles.
Findings are detailed in a research paper appearing online in Transactions on Biomedical Engineering. The paper was written by research assistant professor Teimour Maleki, doctoral students Ning Cao and Seung Hyun Song, Indiana University School of Medicine assistant professor of clinical radiation oncology Song-Chu (Arthur) Ko, and professor of electrical and computer engineering and biomedical engineering Babak Ziaie.
© 2011 Penton Media, Inc.
