Advancing its standard series, Clippard introduces a high-flow pinch valve with an extended stroke for applications that demand increased fluid flow or handling of viscous and particulate-laden substances. Each valve includes 12 in. (30 cm) of silicone tubing, available in medical/laboratory grade or sanitary food grade options.
READ MORE: Pressure Controllers Provide Steady, Repeatable Performance
Key features of the valves include:
- Unobstructed flow path
- 12 in. of pre-installed silicone tubing
- Tubing is easily replaceable
- Higher flow
- Longer stroke.
The valves are compatible with a range of tube types and are suitable for medical and analytical testing, dialysis, bioprocessing, drug manufacturing, chemical processing, water and wastewater treatment, food processing, pulp processing and more.
