Standard washers - Bokers Inc.
The washers come in a wide variety of materials, diameters, thicknesses, and finishes.
The standard flat washers come in short, medium, and long runs, with outside diameters ranging from 0.081 to 5.000 in. The washers have a variety of inside-diameter, thickness, heat-treatment, finishing, and plating options. Washers can be wrought, USS flat washers, SAE flat washers, fender washers, machine-screw washers, ANSI metric plain and B18.22.1 American standard type A and B washers. The standard washers come in low-carbon sheet steel, spring steels, stainless steel, aluminum, brass, copper, nickel silver, ABS, acetal, polyester, nylon, polycarbonate, polyethylene, NEMA-grade laminates and other materials.Boker's Inc., 3104 Snelling Ave., Minneapolis, MN 55406-1937, (800) 927-4377, www.bokers.com
Jessica Shapiro
