Machinedesign 7419 Mdwhitepaper 27
Cable Grounding Methods Compared
April 4, 2016
Sponsored by Lapp Group
To select the best grounding method for shielded cable installations, you have to strike a balance between  installed cost and grounding performance. Yet that’s easier said than  done. Some of the most common grounding  methods, while seemingly inexpensive in terms of the component cost,  require labor-intensive installation procedures that can drive up  installed cost significantly. Other methods lack the full 360º contact between the grounding hardware and the cable braid, reducing the effectiveness of the grounding connection and protection against EMI.Download Now
VICIS Case Study
