Split-roller bearings - Cooper Split Roller Bearing Corp.
Fully interchangeable with the company’s 01 and 02 Series bearings, the new 01E (medium-duty) and 02E (heavy-duty) split-roller bearings provide up to 29% more radial capacity and 16 to 90% more axial-load capacity.
The bearings are completely split to the shaft, eliminating the need to disassemble all components on a shaft for service or replacement, and significantly reducing downtime. The bearings are available with bore sizes from 6.5 to 12 in. Typical applications include mining equipment, industrial fans and conveyors, and power generation.
Cooper Split Roller Bearing Corp., 5365 Robin Hood Rd., Suite B, Norfolk, VA 23513, (757) 460-0925,
www.cooperbearings.com
