Vacuum-Rated Encoders
Sept. 14, 2006
Mercury 1500V (M1500V) digital output encoders are rated to 1 X 10- 8 torr of vacuum.
Mercury 1500V (M1500V) digital output encoders are rated to 1 X 10- 8 torr of vacuum. The sensor is vented, rated for 48-hr bake out at 150°C, and works with both linear and rotary glass scales. Available resolutions range from 5 to 0.50 m (linear), or 6,600 to 655,000 CPR (rotary). Factory-set interpolation levels are X4, X8, X20, or X40. The sensor, which is 8.4-mm tall and weighs 2.7 gm, directly produces A-quad-B and bidirectional index window digital outputs. Its low Z-height lets the encoder work with motion platform designs in semiconductor-processing equipment, electron microscopy, and other vacuum-rated applications. With an alignment tolerance of ±2°, the sensor aligns in 30 sec or less without instrumentation. The system is EMI shielded against electrical noise and has flying leads for termination at the vacuum wall.
MicroE Systems, 8 Erie Dr., Natick, MA 01760, (508) 903-5000, microesys.com
In the rapidly evolving landscape of industrial manufacturing, reliability, productivity, and worker safety take precedence. However, traditional connectivity approaches often...
June 6, 2025
Amidst the rapid evolution of electronics manufacturing, reliability, productivity, and worker safety remain paramount concerns. Yet, traditional connectivity methods often falter...
June 6, 2025
While many within the industrial manufacturing sector grasp the importance of smart manufacturing for optimizing processes, boosting productivity, and future-proofing operations...
June 6, 2025
For electronics manufacturers grappling with formidable challenges, navigating the path to success requires adapting to the dynamic landscape of the industry. How can electronics...
