Thermotstats For Heating Apps
TL-Series thermostats are factory calibrated to user specifications with either fixed or adjustable settings.
May 20, 2004
They're available in three models measuring from room temperature to 518°F and come with creep action contacts for opening. Bimetal thermostats can be ordered with either setscrew or adjustment shaft and are mounted using a simple screw in a 4.2-mm hole. Units are rated for 100,000 cycles with input voltage to 150 Vac and current to 10 A. Other features include dielectric strength to 1,500 Vac/1 min and nickel-plated steel terminal options of either screw or solder terminals.
Selco Products,
605 South East St., Anaheim, CA 92805,
(800) 229-2332,
www.selcoproducts.com
