Tabletop Robot
July 27, 2006
The TT Table-Top Robot has a rigid base of extruded aluminum, a highaccuracy ball screw, and servocontrol motor that provides position repeatability of ±0.02 mm and eliminates misstepping.
The TT Table-Top Robot has a rigid base of extruded aluminum, a highaccuracy ball screw, and servocontrol motor that provides position repeatability of ±0.02 mm and eliminates misstepping. Path accuracy and constant speed are attained through a built-in X-SEL controller. Programming the TT is done with a teach pendant or PC software. The robot comes in either gate or cantilever types.
The gate-type Y axis is fixed for high rigidity to withstand unbalanced loads. Gate types are also recommended for applications where the Z axis receives a heavy load and where a large portion of the load overhangs the slider. The cantilever type provides a wideopen work surface to accommodate larger loads or those with an irregular shape in a fixed condition.
The TT Type 2020 operating range handles 200 ×200 mm while the Type 4040 works over a 400 × 400-mm range. Two or three-axis models may be specified. The three-axis version comes standard with a Z-axis brake to keep the slider from falling when power is off. Data acquisition and transmission is handled via DeviceNet, CC-Link, ProfiBus, or Ethernet.
IAI America Inc., 1261 Hamilton Pkwy., Itasca, IL 60143,
(800) 944-0333, intelligentactuator.com
