Slit-type plastic couplings - Sterling Instrument
Feb. 18, 2010
The S50TLC... Inch and Metric Series lightweight, slit-type plastic couplings are UV resistance, and feature voltage and RF isolation.
A new series of slit-type plastic couplings feature UV resistance, and voltage and RF isolation. The S50TLC... Inch and Metric Series come in sizes 13, 19, and 25. The lightweight molded coupling replaces stainless/aluminum slit-type couplings with low cost and improved operation. There is no windup, backlash, or derating for reversing applications. A metal screw-to-metal nut design ensures a tight fit between the shaft and coupling and does not use threads cut into the molded piece.
Made of engineered polymer with stainless-steel fasteners, the couplings come in 0.125 to 0.500-in. bore sizes and range in length from 0.710 to 1.400 in. Their maximum temperature range is –4 to 284°F.
Sterling Instrument, 2101 Jericho Turnpike, Box 5416, New Hyde Park, NY 11042, (516) 328-3300,
http://sdp-si.com/web/html/newprdcouplings10.htm
Sept. 16, 2025
Sept. 16, 2025
Aug. 22, 2025
