Servocouplings
April 1, 2010
Floating shaft couplings Floating Shaft CD couplings provide a torsionally stiff, zero-backlash option for connecting long distances between shaft ends.
Features & benefits
  • Flex element made of composite material simultaneously allows high torsional stiffness and low bearing loads
  • Custom designs available: Torques from 270 to 550,000 in.-lb; speeds from 500 to 15,000 rpm; lengths from 46 to 196 in.; hub ODs from 2.25 to 12 in.
  • Spacer materials include aluminum, steel, stainless steel, and titanium; custom finishes and several hub options available
Zero-Max Inc. (800) 533-1731 www.zero-max.com
Steel bellows coupling
The backlash-free primeflex coupling can be plugged in for easy installation and disassembly.
Features & benefits
  • Can be dismantled safely without putting the steel bellows at risk, even after long operating periods
  • Mounts easily to shafts via clamping or shrink disk connections
  • Compensates for axial, radial, and angular shaft misalignments
  • Torque transmitted with frictional locking or frictional and positive locking
Mayr Corp. (201) 445-7210 www.mayrcorp.com
Slit type plastic couplings
S50TLC Inch and Metric Series couplings offer low cost, UV resistance, and voltage and RF isolation.
Features & benefits
  • Sizes 13, 19, and 25 available; made of engineered polymer with stainless steel fasteners
  • Can replace stainless or aluminum versions; lower cost, lighter weight
  • No windup, backlash, or derating for reversing applications; suitable for tight or skewed connections
  • Bore sizes from 0.125 to 0.50 in.; lengths from 0.71 to 1.40 in.
Sterling Instrument (516) 328-3300 www.sdp-si.com/eStore
Adjustable line shafts
By using a high-strength intermediate collar between two telescoping sections of precision tubing, EZV line shafts locate phase adjustment apparatus in an accessible space.
Features & benefits
  • Adjustable for both length and phase; torque ratings to 1,200 Nm; lengths to 4 m
  • For different machines, alternate hub designs are available, such as EK7 expanding mandrels and EK6 high strength conical clamp ends
  • Can also be made with torsionally rigid bellows couplings or integral mechanical torque limiters
R+W America L.P. (630) 521-9911 www.rw-america.com
