Sealed Bearing Cartridges
Oct. 12, 2006
Sealed bearing cartridges offer a costeffective, maintenance-free alternative to conventional greased bronze, hardened steel, and rolling-element bearings in demanding applications including off-highway, construction and earth-moving equipment. specific locations include articulating joints, linkages, king pins, lift and steering cylinders, and suspension-track and axle trunnions.
The self-lubricating, sealed bearing cartridges eliminate the need for continuous maintenance, costly automated greasing systems, and environmentally harmful lubricants. The bearings handle loads to 90,000 lbf/in. 2 (620 Mpa). Independent tests show they have an average wear rate just 13% that of hardened steel bearings. The bearing cartridges are also dimensionally stable and provide excellent corrosion resistance. Integral lip seals exclude contaminants from the bearings, and a zinc-plated steel outer shell protects them from compressive loads.
The sealed bearing cartridges come with Gar-Max or high-strength HSG filament-wound plain bearings. Both feature a sliding layer composed of continuous-wound PTFE and highstrength fibers encapsulated in an internally lubricated, high-temperature filled epoxy resin. Backing the sliding layer is continuous-wound fiberglass encapsulated in a high-temperature epoxy resin.
The bearing cartridges come in a range of standard dimensions to accommodate shaft diameters of 1 to 4 in. and housing bores from 1.75 to 4.875 in. Nonstandard sizes are also available.
GGB North America, 700 Mid Atlantic Pkwy., Thorofare, NJ 08086, (856) 848-3200, www.ggbearings.com
June 25, 2025
June 25, 2025
In this insightful on-demand webinar, discover the latest trends and gain expert-driven solutions to today's robotic actuation challenges.
June 25, 2025
maxon drive systems are among the most flown drives in space research, and in space they power some of the most complex robotic systems that humans have ever built.
