All the devices feature a low forward-voltage drop and special wide-bottom-plate designs that provide greater heat dissipation than other packages of similar sizes. The single or dual-chip, surface-mount SMPC (TO-277A) package features solder pads that are compatible with other SMDs, so no modification is needed to the PCB layout for use as higher-performing upgrades to existing devices.
Vishay Intertechnology Inc., 63 Lancaster Ave., Malvern, PA 19355, (619) 336-0860, vishay.com
Sept. 16, 2025
Sept. 16, 2025
Aug. 22, 2025
