Rotary Actuators
June 2, 2005
SRU rotary actuators employ piston guidance sleeves in a lightweight-aluminum housing.
The radial-clamped, endstop adjustments permit easy access and fully adjustable rotation angles from 0 to 180°. The housing has mounting patterns on both the bottom and side for easy implementation. An internal mechanical-ball locking mechanism provides rigid center-position locking and dampening as at the end positions. A standard hydraulic shock absorber gives smooth, fast, and accurate positioning.
Bore size ranges from 20 to 60-mm diameter and is available in both single and double-powered versions for torques from 1.5 to 72 N-m. Air feed through, inductive and magnetic position sensing, and flexible center bores round out the package.
Schunk Inc.
211 Kitty Hawk Dr.
Morrisville, NC 27560
(800) 772-4865
schunk-usa.com
