Rotary Actuator
Oct. 12, 2006
The A752 rotary actuator is only 1.5-in. deep but delivers 36 lb-in. of torque at 80 psi. It gives dual-rack performance, with no backlash at the ends of rotation, over 100° of shaft rotation with an end-to-end dimension under 4 in. Roller-burnished bores assure long life and guide grooves position optional magnetic switches.
The A752 rotary actuator is only 1.5-in. deep but delivers 36 lb-in. of torque at 80 psi. It gives dual-rack performance, with no backlash at the ends of rotation, over 100° of shaft rotation with an end-to-end dimension under 4 in. Roller-burnished bores assure long life and guide grooves position optional magnetic switches. An optional hollow shaft couples its load as a system component.
Rotomation, 11 Sunshine Blvd., Ormond Beach, FL 32174, (386) 676-6377, rotomation.com
