Resin-Based Adhesive/Sealant
The Polymer System Supreme 10HTFL has a service temperature range of –300 to 300°F.
The Polymer System Supreme 10HTFL has a service temperature range of 300 to 300°F. The one-component epoxy-resin-based adhesive/sealant cures readily to a tough, strong thermoset polymer at temperature of 250 to 300°F and up. The material stays liquid indefinitely at room temperature and needs no refrigeration. It adheres to both metallic and nonmetallic substrates. Tensile lap shear strengths exceeding 2,000 psi and T-peels better than 60 pli are possible when bonding aluminum. The system resists severe thermal and mechanical shock and vibration, as well as attack from water, salts, oils, fuels, and organic solvents.
Master Bond Inc.,
154 Hobart St., Hackensack, NJ 07601,
(201) 343-8983, masterbond.com
