Reservoir Breathers
June 7, 2007
Water contamination causes major problems in hydraulic systems and oil-wetted machinery.
New Thermally Reactive Advanced Protection (TRAP) breathers eliminate moisture from hydraulic reservoirs. The breathers contain a porous thin-film network coated with water-absorbing chemicals. The resulting high-surface-area absorbent rapidly removes water vapor from air while minimizing size and weight. TRAP breathers remove atmospheric moisture at only 15% relative humidity and expel moisture with every flow cycle, regenerating water-holding capacity and giving long breather life. The open-porous structure minimizes restrictions and does not impede airflow. The breathers are available in ABS plastic and epoxy-coated steel, with NPT, BSP, and bayonet connections and an optional electronic indicator.
Donaldson Co., Box 1299, Minneapolis, MN 55440, (952) 887-3131, donaldson.com
March 13, 2024
March 13, 2024
March 13, 2024
March 13, 2024
