Profinet connectors - Sealcon
May 8, 2010
The Hummel M23-based Profinet high-speed industrial Ethernet connector, combines Ethernet, data, or power lines in one single interconnect package.
The Hummel M23-based Profinet high-speed industrial Ethernet connector, combines Ethernet, data, or power lines in one single interconnect package. The connector carries up to five individual EMI-shielded circuits and guarantees safe transmission up to Gigabit range without interference. Connecting components are HF-technically matched to a resistance of 100 Ω at 100 Mbit, eliminating cross-talking.
The brass-alloy-cast connectors are flame resistant (Twinax-inserts are V0 rated according to UL-94); vibration safe, and have crimp contacts. Available options include straight, elbow, and panel mounts (front and rear); crimp and PCB-mount connectors, I/O modules, adapter, flange, and conduit adapter. The unit has four shielded Twinax-inserts for data transfers, 12 additional contacts for transmission of signal and power achieve maximum power density/effectiveness within the M23 housing (Signal 4 × 2 each 0.6-mm contacts) 0.08 to 0.34 sq mm – 28 to 22 awg (CAT6 - 0.25 sq mm) and 12 × 1 (0.25 to 1.5 sq mm).
Sealcon, 14853 E. Hinsdale Ave., Suite D, Centennial, CO 80112, (800) 456-9012, www.sealconusa.com
© 2010 Penton Media, Inc.
