Product Spotlight: Endless Timing Belts
Dec. 9, 2008
The AT 3 truly endless timing belts have no weld zone and its belt-tension member is uninterrupted for higher tensile strength compared to a spliced and welded timing belt.
The AT 3 truly endless timing belts have no weld zone and its belt-tension member is uninterrupted for higher tensile strength compared to a spliced and welded timing belt. The belts come in 6, 10, 16, 25, and 32 mm widths, in lengths ranging from 720 to 1,701 mm. Depending on belt width, allowable tensile strength varies from 190 to 1,400 N. The tension member comes in steel or stainless steel. Available options include a nylon facing on the tooth side for lower friction and zero-backlash pulleys for bidirectional belt drives.
BRECOflex Co. L.L.C.
222 Industrial Way W
Eatontown, NJ 07724
(888) 463-1400
brecoflex.com
