Pneumatic slides
Ultra series slides are available with two cylinder options — M-series or ISO/VDMA 6432 — for long strokes.
FEATURES & BENEFITS
  • Eight bore sizes from 5/16 to 11/16 imperial; and 8 to 25 mm ISO/VDMA
  • Alignment coupler isolates piston rod from side loading to extend life with 360° float
  • Square bearing block maximizes loading and lowers stick slip
  • Larger bores come with two rail blocks
NUMATICS
Avon, Ohio
(440) 934-3200
www.numatics.com
Circle 289
Hygienic actuator
HYG guided hygienic actuator provides high-loading capabilities in washdown or liquid environments.
FEATURES & BENEFITS
  • Six sizes from 20 to 63 mm with stroke lengths to 200 mm
  • Resists water, machining coolant, and other liquids
  • Outperforms other cylinders when liquids make direct contact with sliding cylinder parts
  • Multiple porting locations (top or side porting), rail-mounted hygienic auto-switch, and recessed guide rods standard
SMC CORP. OF AMERICA
Indianapolis, Ind.
(317) 899-4650
www.smcusa.com
Circle 290
