Standard throat depth is 6 in. (152.4 mm). Maximum downward force is 2,120 lb at 100 psi. It has programmable cycle time and head-forming pressure, vertical head-height adjustment of 6.50 in. (165 mm), a touchscreen with pushbutton on/off and emergency stop, and advance and return limit switches. The riveter also has dual-palm button anti-tie-down actuation, adjustable digital dwell timer (0 to 99 sec), cycle counter, and programmable Z axis to vary stroke.
Orbitform Group, 1600 Executive Dr., Jackson, MI 49203, (517) 787-9447,
