The SMVector Frequency Inverter now features an internal disconnect switch that removes power to facilitate service and maintenance. Use of the switch in decentralized “point-of-use” operations results in reduced downtime. The switch eliminates the need for a separate external disconnect switch and associated wiring. Because the switch is lockable in the off position, the motor can be serviced while still connected to the SMVector drive.
Lenze-AC Tech, 630 Douglas St., Uxbridge, MA 01569, (800) 217-9100, lenzeactech.com
