New Products: Electro-Optic Level Switch
ELS-1150 Series electro-optic switch is designed for high-temperature and high-pressure applications
June 16, 2009
The ELS-1150 Series electro-optic switch is designed for high-temperature and high-pressure applications. A strong fused-glass prism eliminates leak potential and handles extreme temperature and pressure applications up to 2,500 psi.
Two versions are available — FM and EP — with wide voltage ranges and temperature ranges up to 125°C (ELS-1150XP). The small sensors, available in nickel-plated carbon steel or stainless steel, are suitable for monitoring the small, pressurized vessels found in HVAC, refrigeration, and hydraulic applications, and are used for low, high, and intermediate level detection. The ELS-1150SS stainless-steel version is for applications requiring corrosion resistance.
Gems Sensors & Controls
One Cowles Rd.
Plainville, CT 06062
(800) 378-1600
www.gemssensors.com
