Dc gearmotor
M1600 G211 series of single-worm reduction, right-angle gearmotors is designed for applications requiring moderate output torque.
Features & benefits
Speeds to 500 rpm; ratings to 15 lb-in.
8:1 to 60:1 ratios and 12-115 Vdc
High-energy ceramic magnets, double-shielded ball bearings (motor), and sleeve bearings
Externally replaceable brushes, Class F insulation, and auto-hook tang type commutator
RAE Corp.
(815) 385-3500
www.raemotors.com
Circle 160
Linear actuators
Size 14 hybrid linear actuators are available with an integrated connector, and are offered alone or with a harness assembly and a positive latch for high connection integrity.
Features& benefits
Connector rated to 3 A and handles wire gauges from 22 to 28
Suits applications that require a direct plug-in to pre-existing harnesses
Three designs — captive, non-captive, and external linear — available in resolutions from 0.00012 to 0.00192 in./step
Deliver thrusts to 50 lb
Can be micro stepped for even finer resolutions
Haydon Switch & Instrument Inc.
(800) 243-2715
www.hsi-inc.com
Circle 161
Stainless-steel shafts
SS2 through SS8 series of spline shafts are available in 304 stainless steel for light to moderate load applications, including those that require a rotary drive with adjustable linear position or a linear guide with high torsional stability.
Features & benefits
Range from ⅛ to ½-in. diameters, and include the full range of bushing options for these sizes
Include low-friction Kerkote TFE coating to eliminate external lubrication and maintenance
Available with any combination of basic or anti-backlash bushing, plain or thread mount bushing, and ¼, ⅜, ½, or ¾-in. diameter shaft
Kerk Motion Products Inc.
(603) 465-7227
www.kerkmotion.com
Circle 162
Linear magnetic encoders
LM10 linear magnetic encoders offer 100-m travel capability and fit-and-forget operating life to high-speed and high-precision positioning for tough machinery applications.
Features & benefits
Solid-state, non-contact design features compact, IP68 readhead that rides at 0.1 to 1.5 mm standoff over a self-adhesive magnetic strip scale
Scale coils available as cut-to-length or in lengths to 100 m
Operating temperatures from -20° to 85°C, water-proof sealing to IP68, and high resistance to shock, vibrations, and pressure
Digital or analog output models offer customer-selectable resolutions including 1, 5, 10, 50, and 100 µm
Maximum velocity of 25 m/sec for sinusoidal output; digital models position at 25 m/sec for outputs at 100, 50, and 10 µm resolution; 20 m/sec at 5 µm resolution, and 4 m/sec at 1 µm
Renishaw Inc.
(847) 286-9953
www.renishaw.com/encoders
Circle 163
Bevel gearboxes
HDP parallel shaft and HDO right angle gearboxes offer high structural rigidity and gear geometry for optimized load capacity and gear/bearing life.
Features & benefits
Current range: nine sizes offer 90 to 180 mm output shaft range covering 124,000 to 650,000 lb-in. output torque
Two new sizes will cover output shafts to 210 mm and output torque of 1,200,000 lb-in.
Spheroidal cast iron housings
SKF Explorer bearings increase shaft bearing life up to 60%
Noise levels and vibrations are minimized by using structural simulations based on Boundary Element Method analysis
Bonfiglioli USA
(859) 334-3333
www.bonfiglioliusa.com
Circle 164
Linear slide
RRL low profile slide is a compact, precision, linear solution for applications that require a small footprint without sacrificing quality.
Features & benefits
Offers smooth and quiet motion over long lengths and high loads
Rail can be cut to lengths up to 12 ft
Carriages consist of sealed double row bearings
T-slot components with three mounting configurations
Load ratings of 110 lb (axial) and 270 lb (radial)
Pacific Bearing Co.
(800) 962-8979
www.pacific-bearing.com
Circle 165
Vector drives
SMVector Inverters come with polycarbonate plastic NEMA 4X (IP65) enclosures for use with drives that need to be protected against dust, dirt, and the harmful effects of water and corrosion.
Features & benefits
Intended for both indoor and outdoor use
UV resistant; has an improved resistance to low temperature impact
Universal inputs (120 - 600 Vac) up to 10 hp, with plans to expand to 30 hp
Lenze-AC Tech
(508) 278-9100
www.lenze-actech.com
Circle 166
Drive belt
PowerGrip TruMotion small-pitch, non-marking belt is engineered for drives requiring precision, cleanliness, and reduced noise levels.
Features & benefits
Nylon tooth surface reduces dust accumulation (4.5 times less dust generation than a neoprene belt)
Three tooth profiles — timing, HTD, and curvilinear — offer exact meshing characteristics for improved registration and elimination of tooth slip
Hardened fiberglass tensile cords provide high flex life, and resistance to elongation
Clean-running polymer compound body handles temperatures from -40° to 220° F
Gates Corp.
(720) 283-8555
www.gates.com/trumotion
Circle 167
Motor optimizers
Powerboss Integra is a fixed-speed motor solution that dynamically adjusts power to a motor as its load changes.
Features & benefits
Constantly monitors motor's load and calculates exact amount of power required at any time
Reduces amount of electricity used, increases life-span of motors, and reduces maintenance requirements and amount of carbon dioxide produced at the point of generation
3-phase offers 220 to 1100 V; single-phase offers 110 to 220 V
Six sizes come with in-built soft starter
BC International
(714) 779-1556
www.boschems.com
Circle 168
Closed-loop drives
Digital MD plus series of field-programmable, closed-loop drives for dc motors up to 2 hp features an isolated 4-20 mA input/output signal capability.
Features & benefits
Uses an advanced velocity-form PID algorithm for accurate and responsive control
Isolated 4-20 mA input and output for easy integration with existing process control systems
Universal power supply supports 85-265 Vac input
⅛ or ¼ DIN panel mount with NEMA 4X faceplate or NEMA 4 stand-alone enclosure
Displays set point or actual running speed; adjustable PID settings
Dart Controls Inc.
(317) 873-5211
www.dartcontrols.com
Circle 169
Bellows couplings
MK1/0.5 miniature bellows couplings provide increased control and compensate for misalignment and transmit angular position, torque, and velocity with a high level of accuracy at even high speeds.
Features & benefits
- Use formed bronze bellows
- Speeds of 100,000-plus rpm
- Torque rating of 7 oz-in. within an outside diameter of 6.5 mm
- Custom bore sizes available from 1 to 3 mm
R+W America
(630) 521-9911
www.rw-america.com
Circle 170
