New Products
Sept. 1, 2007
Miniature curvilinear sensor C-Series sensor provides precise curvilinear measurements and features a new face and side sealing on the core plastic housing.
Features & benefits
  • Modular architecture built on base core sensor for easy integration
  • Allows greater versatility in installation options such as rotating shafts, balances, steering assemblies, and other applications where less than 270° of rotation needs to be monitored
  • Optional IP67-rated packaging effectively houses the core sensor
  • Optional 5 and 12-V supply module allows system to support changing supply requirements
MTS Systems Corp., Sensors Div.
(919) 677-2314
www.mtssensors.com
Circle 156
Conveyor chains
MicroSpan transfer is an alternative to roller transfers, featuring a tight-knit power plastic chain that provides a stable, flexible base for smooth transport of products.
Features & benefits
  • 140 ft/min maximum speed
  • Stainless steel and plastic ideal for washdown applications
  • Can be slave-driven by another conveyor or independently driven
  • Sprocket-driven design eliminates tracking problems
SpanTech LLC
(270) 651-9166
www.spantechllc.com
Circle 157
Ethernet switches
IP67-rated Industrial Ethernet switches operate in extreme environmental conditions, featuring a flammability rating of UL94 V0 with industry standard M12 sealed connection ports.
Features & benefits
  • Allows deployment of Ethernet-based control systems directly onto a machine, process, or factory floor vs. running cables or using enclosures
  • Unmanaged version and a full featured managed version, which supports VLAN, QoS, port trunking, port mirroring, SNMP, DHCP, and is auto crossing/auto negotiating
  • Eight 10/100 Ethernet ports along with dual power contacts and serial interface port for set-up and diagnostics
  • Ports feature M12 connections
Weidmüller
(804) 794-2877
www.weidmuller.com
Circle 158
Linear slides
Linear slides feature an anodized aluminum body with a built-in repairable air cylinder and a combination of mounting holes to facilitate rigid mounting in tight spaces.
Features & benefits
  • 12, 20, and 32-mm bores with strokes from ½ to 10 in.
  • Guide shafts from ⅜ to ¾-in. diameters
  • Toolbar has counterbored tapped thruholes on top, front, and bottom faces for quick tooling attachment
  • Front face has slip-fit dowel hole and slot for repeatable precision tool alignment
Fabco-Air Inc.
(352) 373-3578
www.fabco-air.com
Circle 159
Brushless dc motors
Pittman brand Elcom ST series N2300 slotted brushless dc motors incorporate internal Hall sensor feedback for linear speed-torque characteristics, high starting torque, and variable speed control (with appropriate control electronics).
Features & benefits
  • 6-slot lamination design contributes to high power, fast acceleration, consistent operation, and long service life
  • Available in four standard stack lengths — ½, 1, 1½, and 2 in.
  • Integrate high-energy neodymium iron boron magnets
  • Speeds to 8,000 rpm and continuous torque to 40 oz-in.
Ametek Technical & Industrial Products
(330) 673-3452
www.ametektechnicalproducts.com
Circle 160
Linear bushings
Linear ball bushings are available in 259 different varieties for most factory automation applications.
Features & benefits
  • 52100 bearing steel or 440C stainless-steel materials
  • Electroless nickel plating offered as an optional surface treatment for 52100 bearing steel
  • Compatible spacers, stopper plates, and mounting housings available
Misumi USA Inc.
(800) 681-7475
www.misumiusa.com
Circle 161
Small servodrives
Allen-Bradley Kinetix 2000 servodrives offer power ranges of 300 W to 3 kW, suitable for small packaging applications.
Features & benefits
  • Integrates with Allen-Bradley Logix controllers, servomotors, and actuators
  • Modular design minimizes wiring time and costs
  • Single power rail serves as both a mounting and connecting system, simplifying design and installation
Rockwell Automation
(800) 223-5354
www.ab.com
Circle 162
Precision ball bearings
EZO-SPB miniature ball bearings feature balls that are smaller than those found in a ballpoint pen, making them suitable for any product requiring miniaturization with smooth, quiet motion.
Features & benefits
  • 0.06-mm or 0.0236-in. shaft I.D.
  • 2.5-mm O.D. and 1.0-mm wide
  • Five balls in each race
  • Balls are precision ground to ensure long life at operating speeds from 142,000 to 160,000 rpm
SPB-USA LLC
(941) 358-1655
www.spb-usa.com
Circle 163
Magnetic angular sensors
Posirot PRAS3 magnetic angular position sensor uses an internal, contact-free permanent magnet to determine the angular position in harsh environments.
Features & benefits
  • Compact 1.4-in. diameter housing
  • Measurement ranges are available in 15° increments: 0-15°, 0-30°, 0-45,° and up to 0-360°
  • Two extr-astrong ball bearings handle axial and radial loads along sensor's 10-mm shaft
  • Three analog outputs available — 0.5 to 4.5 V, 0.5 to 10 V, and 4 to 20 mA
  • ± 0.03% over the fullscale resolution and repeatability; 0.3% over the full-scale linearity
ASM Sensors Inc.
(630) 832-3202
www.asmsensors.com
Circle 164
Air cylinders
Twin Rod air cylinders feature less than ⅓ of a degree of rotation, allowing precise rod alignment and virtually eliminating rod endplay for guided linear motion.
Features & benefits
  • Rectangular body simplifies mounting, saves space in multiple applications, and makes it easy to achieve precise angles
  • Single and double acting models, with strokes from ½ to 4 in.
  • Built-in fine stroke adjustment, in six bore sizes from ¼ to 1¼ in.
  • Integral magnets permit mounting sensor switches on three sides
  • Rod end plate accepts a range of other pneumatic devices
Humphrey Products Co.(269) 381-5500
www.humphrey-products.com
Circle 165
Linear slide
RGS 10000 slide is a self-contained, screw-driven linear slide that offers high linear speed, accurate positioning, and long life in a compact assembly.
Features & benefits
  • Handles dynamic axial loads to 100 lb
  • Speeds of more than 60 in./sec
  • Backlash and maintenance free
  • Standard leads include 0.100, 0.200, 0.500, and 1.00 in. travel per revolution
Kerk Motion Products
(603) 465-7227
www.kerkmotion.com
Circle 166
Web-ready controller
Blue Fusion model 5300 web-enabled automation controllers let users securely monitor and control process variables over the Internet or intranets using a standard web browser.
Features & benefits
  • Lets users create graphical HMI projects hosted on the 5300's web server
  • Suitable for SCADA applications, especially those requiring 24-hour remote access
  • I/O modules available in 4, 8, 16, and 32 channel versions, featuring pluggable terminal blocks for direct wiring
  • Supports up to 1,024 I/O points and up to 16 axes of motion control
Control Technology Corp.
(508) 435-9595
www.ctc-control.com
Circle 167
LED projectors
LED spot projectors are compact, high-intensity LED spotlights that are designed to replace conventional halogen point-sources as well as fiber optic illumination solutions.
Features & benefits
  • Wavelengths include red, blue, green, amber, and broadband white
  • Provide light at divergence angles of 10 or 25°
  • Offer long lifetimes and low power consumption when compared to traditional light sources
  • Optional fiber-coupled configurations allow users to bring light to desired target using industry standard fiber components
StockerYale Inc.
(603) 893-8778
www.stockeryale.com
Circle 168
Servomotor controller
SilverDust IGC CANopen servomotor controller is a single-axis controller that includes serial communications (RS-232 and RS-485), CANopen, and 7 I/O.
Features & benefits
  • CANopen can be configured peer-to-peer or master/slave for sharing I/O with other controllers or devices
  • RS-232 and RS-485 run in parallel to CANopen for supervisory control of host
  • In multi-axis systems, one IGC serves as master while others receive motion commands
  • Includes breakouts for power and communications
QuickSilver Controls Inc.
(888) 660-3801
www.quicksilvercontrols.com
Circle 169
Capacitive sensors
Normally open/normally closed selector switches come on ac/dc 30-mm capacitive sensors, reducing need for complicated wiring or need to reverse wiring to change output.
Features & benefits
  • Detect metal and nonmetal objects
  • Housed in metallic or plastic cylindrical threaded casings; adjustable operating distance to 25 mm
  • Resist water, dust, shock, and vibration
  • LED, short circuit protection, IP65 protection, cable or connector versions, CE marked, and RoHS compliant
Fargo Controls Inc.
(800) 241-3755
www.fargocontrols.com
Circle 170
Timing pulleys
High-precision timing pulleys can be used with timing belts to ensure perfect meshing, resulting in long service life and high accuracy of belt drives.
Features & benefits
  • English and metric pitches as well as flat idlers
  • Aluminum models offer light weight and reduced inertia for moderate power transmission
  • Steel and stainless-steel models are suitable for high power transmission and are highly durable
  • Delrin models are suitable for limited power transmission; nonmetallic design requires use of stainless-steel flanges
Brecoflex Co. LLC
(888) 463-1400
www.brecoflex.com
Circle 171
Microstepping driver, motor
PRO series NEMA-17 integrated motor/drivers conserve space, featuring a 42-mm hybrid motor with attached drive electronics that deliver accurate open loop control.
Features & benefits
  • Two models, PRO 42AP 1/500 microstepping, and PRO 42BP ⅛ microstepping are available
  • Provides high torque density and simplified operation to eliminate need to run motor power management cabling through machine and reduce potential for electrical noise
  • Available in case lengths of 40, 48, and 60 mm; produce maximum holding torques (bipolar) ranging from 300 to 440 mNm
  • AP offers 100,000 steps and BP offers 16,000 steps resolution
  • Suitable for positioning applications
Nippon Pulse America Inc.
(540) 633-1677
www.nipponpulse.com
Circle 172
Graphical software
LabView 8.5 is the latest version of the graphical system design platform for test, control, and embedded system development.
Features & benefits
  • Simplifies multicore and FPGA-based application development with intuitive parallel dataflow language
  • Delivers faster test throughput, more efficient processor-intensive analysis, and more reliable real-time systems on dedicated processor cores
  • Extends Lab-View platform into embedded and industrial applications with new Statechart design module for modeling and implementing system behavior as well as new I/O libraries and analysis functions for monitoring and control
  • Delivers symmetric multiprocessing with LabView Real-Time environment to allow automatic loading of balance tasks across multiple cores without sacrificing determinism
National Instruments
(888) 280-7645
www.ni.com/labview85
Circle 173
Rodless actuators
Extrak RM and LM Series rodless actuators offer roller screw technology or high speed belt drives to provide electro-mechanical reliability.
Features & benefits
  • Roller screw-driven versions offer higher thrust loads and longer life than ball screw driven rodless actuators
  • Choice of motor brand and type — brushless servo, stepper, dc, or ac motor
  • Input transmission options include direct coupling and parallel belt and pulley drive
  • Metric frame sizes of 65, 80, and 110 mm with stroke lengths to 7.5 m and speeds to more than 9 m/sec
Exlar Corp.
(952) 368-3434
www.exlar.com
Circle 174
Servomotors, amplifiers
Six Alpha HVi series servo models for use in general machine automation come with a DSM324i motion controller.
Features & benefits
  • Voltage input range of 400 to 480 Vac; include separately mounted shared power supply modules
  • Reduce the amount of space needed in the cabinet
  • Eliminate the need for external power resistors to dissipate regenerated energy during motor deceleration
  • Supported by the PACMotion controller
GE Fanuc Automation
(800-433-2682)
www.gefanuc.com
Circle 175
April 29, 2024
