New Products
March 1, 2010
Torque transducers To verify the amount of rotational torque applied by heavy power tools, RTM 2208 and 2209 stationary (non-rotating) transducers accurately
Torque transducers
To verify the amount of rotational torque applied by heavy power tools, RTM 2208 and 2209 stationary (non-rotating) transducers accurately confirm static and dynamic torque.
Features & benefits
  • Can be used while device under test rotates — as when calibrating torque wrenches for drill strings in oilfield applications
  • Carry 300,000 to 3,000,000 lbƒ-in., compact, cost-effective alternative to rotating torque transducers
  • High torsional stiffness, overload, and extraneous load capacity; all models are calibrated CW and CCW to rated load in NVLAP accredited laboratory
S. Himmelstein and Co.
(800) 632-7873
www.himmelstein.com
Cable ties and tools
Cable ties, mounts, and installation tools are resistant to oil, grease, solvent, and petroleum and come in 4 to 32-in. lengths.
Features & benefits
  • Black nylon lashing ties, 9 to 40-in. lengths, also resist oil, grease, solvent, and petroleum
  • Easy-release for removing, repositioning, or reuse — releasable ties come in 6 to 12-in. lengths
  • Mounting head ties, in 4 to 12-in. lengths, feature a one-piece mounting head and cable tie, eliminating separate mounting accessories
  • UV-resistant ties from 7 to 14 in. for outdoor installations requiring high tensile strength and locking-system resistance
AutomationDirect
(800) 633-0405
www.automationdirect.com
Pneumatic actuator
A movable housing linear slide spans seven different bore sizes (9/16 to 3 in.) and five guide shaft diameters.
Features & benefits
  • Available with ball bearings (Model TMH) or composite bearings (Model TEMH) with both styles housed in black-anodized carriages; housing is guided by precision ground, case hardened, chrome-plated shafts powered by round-line cylinders
  • Optional air cushions, internal and external bumpers, magnetic position sensing
Bimba Mfg.
(800) 442-4622
www.bimba.com
Air velocity and temperature transmitter
The FMA1000 series measures and displays air velocity and air temperature of airflows in ducts and pipes in HVAC applications, research labs, and other manufacturing processes.
Features & benefits
  • Backlit LCD displays air velocity and temperature in different engineering units
  • Two analog outputs correspond to air velocity and temperature; high and low velocity voltage alarm outputs; USB serial interface; Windows-based software
  • Sensor probe based on three RTD elements available in fixed top mount, right angle mount, and remote probe configurations
Omega Engineering Inc.
(203) 359-1660
www.omega.com
Precision enclosure cooling
RTT Wireless Sensor intelligent network transmits cooling-unit data wirelessly to initiate service orders.
Features & benefits
  • Power variations caused by pollution quickly identified
  • Variety of sensors and suitable hardware and software for monitoring climate control in enclosures available; TopTherm (RTT) series of climate control units can be easily converted to wireless
  • Up to 32 cooling units can be connected to one wireless I/O unit; internal Web server allows visualization of connected RTT climate control units; measurements via Ethernet with TCP/IP and monitoring system, where data is centrally recorded, evaluated, and archived
  • Radio transmission in license-free ISM band at 2.4 GHz, 50-m range; efficient — supplied with energy by cooling units
Rittal Corp.
(937) 399-0500
www.rittal-corp.com
Power-dense motor
The RE 50 motor is a high-density 200-W ironless rotor for detent-free running and minimized mass inertia.
Features & benefits
  • Combination of a two-pole neodymium permanent magnet with the company's winding technology for high torque and above-average acceleration
  • 50 × 108 mm; available with four different windings
  • Preloaded bearings, 0.38-Nm torque
  • Speed of 2,800 to 5,700 rpm
  • 90% efficiency, low 24.70-Vdc voltage, high power density
maxon precision motors inc.
(508) 677-0520
www.maxonmotorusa.com
Braid-reinforced hose
Flexible Silbrade silicone hose can be used in fluid applications and as protective jacketing.
Features & benefits
  • Open mesh polyester braiding reinforces walls of silicone tubing — handles high pressure and temperatures from -80° to 350° F
  • Tight bend radii and restricted space usage without impeding flow
    • Peroxide-cured Silbrade; nine sizes from ⅛ through 1-in. ID; custom units available, including cut-to-length pieces, colors, and hardnesses
NewAge Industries Inc.
(800) 506-3924
www.newageindustries.com
Air jets
Air Jets come in a range of nozzles, bases, and mounting hardware.
Features & benefits
  • Configurations can be aimed and locked into position, for precise delivery of air or liquid
Clippard Instrument Laboratory Inc.
(513) 521-4261
www.clippard.com
Three-jaw gripper
The PZN-plus Series of three-jaw centric grippers now includes Size 380 for weight to 190 kg.
Features & benefits
  • Multitooth guidance of the three-finger centric gripper employs a large gripping force and high moment load capabilities
  • Versions abound for use in areas with extreme temperature, chemicals, dirt
  • Forces to 59,500 N and strokes of 2 in./jaw; metallic dust covers and Viton seals optional
Schunk Inc.
(919) 572-2705
www.schunk.com
Damping coupling
Arcusaflex® couplings from Ringfeder Power Transmission USA Corp., Westwood, N.J., are used on machines powered by diesel engines and strong pumps, which run less smoothly than electric motors. These soft couplings isolate driven systems from their less-than-steady power sources — particularly helpful where cardan shafts connect the two. Why? Cardan shafts allow shaft displacement and longer distances between driving and driven components, but their torsional flexibility can allow resonant excitation.
As explained by Sarah McChesney, chief engineer at Ringfeder, most isolators (including the Arcusaflex®) don't prevent vibration generation: “Instead, these devices dampen vibration and lower natural machine frequency to below lowest operating speed.” Of course, the other approach to lowering natural frequency is to add mass: “We've helped designers applying reciprocating compressors with tuning by both isolation and mass,” explains McChesney, “because these machines have terrible vibration. Often, a vibrating engine powers the compressor, which compounds the vibration issue with its own excitation. In fact, depending on system specifics, these compressors can only be applied successfully with both isolating couplings and increased mass.”
Ringfeder Corp.
(888) 746-4333
www.ringfeder.com
