The units feature a nickel code disc that provides robust operation and tolerance to temperatures as high as 100ºC. Ball bearings spaced 30-mm apart support the encoder shaft for concentricity of ±0.3/±0.1-mm radial and ±0.5/±0.2-mm axial. Hollow shaft clamping is said to electrically isolate the encoder from the motor shaft for boosted immunity to electrical interference and minimizes runout problems with collets. The VFS 60 encoders are IP65 rated and come with TTL or HTL interfaces.
Sick Stegmann, 7496 Webster St., Dayton, OH 45414, (800) 811-9110, stegmann.com
June 25, 2025
June 25, 2025
