New Product: Modular ac drives
The AC890PX Series takes a modular approach to ac drives that handle up to 600 hp (400 kW) with a voltage range from 380 to 690 Vac.
Nov. 8, 2007
Each plug-in power module slides into the power frame for quick installation and replacement, reducing downtime. The IP52/NEMA-12 enclosure measures 2,000 500 620 mm (79 20 24 in.) and comes with a disconnect switch, fuses, harmonic-reducing input line reactor, and dynamic braking with resistor. The AC890PX can run induction, torque, and permanent-magnet servomotors in simple volts/Hertz, open-loop flux vector, and precision closed-loop vector with positioning control modes. Drive communication is handled with option cards and includes protocols for Ethernet, Profibus, ControlNet, DeviceNet, CANopen, and FireWire.
Parker Hannifin Corp. Automation Group, SSD Drives Div., 9225 Forsyth Park Dr., Charlotte, NC 28273, (704) 588-3246, parker.com
