New Product: Linear Position Sensor
The Positek X111 intrinsically safe linear variable-inductive transducer position sensor is designed for the 50 to 80-mm measurement range.
When used with Positek BX Series galvanic barriers, the device provides a 0.5 to 9.5 Vdc or 4-to-20-mA analog output signal that represents absolute position. The sensors have rugged stainless- steel bodies sealing between IP65 and IP68, depending on cable or connector options.
Everight Precision Technologies Corp.,
102 Commerce Dr., Unit B, Moorestown, NJ 08057,
(856) 727-9500,
everightsensors.com
