New Product: 1-kW Power Supplies
The single-output HWS1000 Series of 1-kW power supplies target process control, ATE, factory automation and other areas that need high reliability and extended life under extreme conditions.
Dec. 13, 2007
These supplies meet SEMI F47 power line sag specs, mandatory for high-volume semiconductor and integrated-circuit (IC) manufacturing equipment. The units are available in 10 nominal output voltages including: 3.3, 5, 6, 7.5, 12, 15, 24, 36, 48 and 60 V. In addition, most models can be adjusted up to ±20% of nominal voltage to accommodate nonstandard system voltages. The 7 through 60-V models have a peak power rating of up to 1.2 kW when operated with a line voltage of 200 Vac or higher. The supplies accept a range of input voltages from 85 to 265 Vac and comply with the EN61000-3-2 power factor and harmonic correction standards. Remote On/Off, DC Good and single-wire Current-Share signals are standard.
Lambda Americas unit of TDK Corp., 3055 Del Sol Blvd., San Diego, CA 92154, (800) LAMBDA-4, lambdapower.com
