Micro-Dispense Nozzles
Sept. 27, 2007
The VHS (very-high-speed) Micro-Dispense Nozzles are designed for applications where the liquid to be dispensed is in the microliter to nanoliter range.
Two versions are available: 062 Minstac threaded ends and straight ends. The Minstac version directly threads into VHS valves equipped with Minstac outlet bosses and provides a leakproof connection to Teflon tubing when the nozzle must be located further from the valve. They remove easily for cleaning or changing orifice sizes. The straight-tube versions accommodate press-on tubing connection to VHS valves with straight outlet ports. Any soft, flexible tubing compatible with the system fluid can be used.
The Lee Co., 2 Pettipaug Rd., Box 424, Westbrook, CT 06498, (860) 399-6281, theleeco.com
