Linearity is better than 0.01% and repeatability is 0.005%. Position update rate is 1.5 kHz. The sensor does not require recalibration after installation. Each sensor carries a waveguide sensing element, conditioning electronics for output position data, and an IP67-rated housing. The sensor can be attached to a machine using adjustable mounting clamps. Electronic connections use standard four-pole socket DIN connectors. Supply voltage is 24 Vdc with 30 Vdc polarity with 36 Vdc overvoltage protection included.
MTS Systems Corp.,
3001 Sheldon Dr., Cary, NC 27513,
(919) 677-0100,
mtssensors.com
