High-Capacity Turntable
Jan. 26, 2006
The AccuRing HCT Series 1 turntable is for general-purpose positioning of heavy loads.
The high-capacity turntable uses a heavy-duty bearing arrangement that provides high axial, radial, and moment-loading capabilities. The table's drive system is isolated from table bearings so that loads on the dial plate are not transmitted to the drive. The unit comes with variable speed, operates on 110 or 220 Vac, and is available in diameters from 12 in. to over 50 ft. Dial plates, mechanical overload protection, and foot-pedal or pushbutton activation are also available.
Centricity Corp., 25 S. State St., Girard, OH 44420, (330) 545-5624, centricity.net
