Gaskets Provide Stable Bolt-Load Retention
Feb. 22, 2007
Select-a-Seal (SAS) Generation II gaskets feature nonrigid composite bases (or carriers) and rubber (polymer) sealing edges.
Select-a-Seal (SAS) Generation II gaskets feature nonrigid composite bases (or carriers) and rubber (polymer) sealing edges. The high-density carrier gives the gaskets long-term, stable bolt-load retention in a wide range of joints and at temperatures up to 175°C. The gaskets are lightweight, corrosion-proof, and durable. They combine both compression and adhesion and can replace alternative seals including RTV silicone, molded-rubber (press-in-place seals), and rubber-coated metal gaskets.
Interface Sealing Solutions,
216 Wohlsen Way, Lancaster, PA 17603,
(877) 942-7537,
interfacesealingsolutions.com
June 27, 2025
June 25, 2025
June 25, 2025
