Machinedesign 3082 Masterbond 10 0
Food-grade epoxy - Master Bond Inc.
June 9, 2011
The two-part epoxy meets FDA and NSF requirements.
EP42HT-2FG two-part, food-grade epoxy meets FDA CFR 175.300 and NSF/ANSI 51.4.1 (2009) requirements. The adhesive resists chemicals, many solvents,  boiling water, steam, radiation, fats and oils, and temperatures from -60 to 450°F. It has volume resistivity over 1014 ohm-cm,  tensile strength over 12,000 psi, and tensile lap-shear strength over 2,000 psi.
Part A is clear and has 55,000 to 110,000-cps viscosity. Part B is amber and has a room-temperature viscosity of 75 to 130 cps. The parts mix at 100:30, and open time for a 100-gm mass at room temperature is 45 to 75 min. Cure is 3 to 4 hr at 150 to 200°F or overnight at room temperature followed by a 2 to 3-hr cure at 150 to 200°F.
The epoxy comes in half-pint, pint, quart, gallon, and 5-gal containers. It has a shelf life of one year when stored unopened at room temperature.
Master Bond Inc., 154 Hobart St., Hackensack, NJ 07601, (201) 343-8983, www.masterbond.com
