It fills gaps and bonds metals, fabrics, glass, wood, and concrete. The epoxy's flexibility, impact resistance, and durability let it secure honeycomb floor and ceiling panels. The material has a viscosity of 80,000 eps, working time of 10 min, fixture time of 20 min, and a functional cure time of 3 hr at 72°F. Bonds pass the Federal 60-sec vertical burn test and the solvent-free formulation has very-low VOC emissions. Typical peel strength of the cured epoxy is 25 pli, impact resistance is 10 ft-lb/in.2, dielectric strength is 800 V/mil, and adhesive tensile lap-shear strength is up to 2,900 psi.
Devcon, 30 Endicott St., Danvers, MA 01923, (800) 933-8266, devcom.com
June 25, 2025
June 25, 2025
