Explosionproof Starter Motor
July 12, 2007
The MS2000 line of explosionproof manual motor starters features push-button actuation with a lock out provision to lock the manual motor start in the off position.
The MS2000 line of explosionproof manual motor starters features push-button actuation with a lock out provision to lock the manual motor start in the off position. The starters are UL Classified and CSA Certified for use in Class I, Division 1 areas. Auxiliary contacts are available with one normally open and one normally closed contact. A shunt release can electronically trip the starter when voltage (120 or 220 V) is applied. A watertight O-ring, stainless-steel cover bolts, and a breather provide NEMA-4X protection.
Adalet, 4801 W. 150 St., Cleveland, OH 44135, (216) 267-9000, adalet.com
Sept. 16, 2025
Sept. 16, 2025
Sept. 16, 2025
